I just hooked up a U46DJ soundcard to my laptop , and when i try ti configure it in 4.1, it gives me an "ASIO driver error, not enough channels" or something along those lines. Does anyone know whats going on?
geposted Mon 04 Dec 06 @ 12:28 am
r u trying to use turntables?
geposted Mon 04 Dec 06 @ 1:04 am
what driver are you trying to use with that ?? 1.014 or 1.016?
geposted Mon 04 Dec 06 @ 1:25 am
1.014
is 1.016 the one????? I need help bad i have a gig friday!!!
geposted Mon 04 Dec 06 @ 4:50 am
uninstall 1.014
then install 1.016 http://www.esiforum.com/show.asp?db=esi&t=esi1&mode=0&msg=2876
reboot
plug in u46 and turn it on then after the u46 is active open vdj and configure
reboot
geposted Mon 04 Dec 06 @ 5:11 am
listen2 wrote :
uninstall 1.014
reboot
reboot
me thinks uv been promoted well done;)
geposted Mon 04 Dec 06 @ 11:28 am
And attach it always to the same usb port. During the installation the sound card is only installed for that particular usb port. If you would like to use it on a port you want, you need to install it on every port.
Ewout
Ewout
geposted Mon 04 Dec 06 @ 9:02 pm
wow....really? This stuff is VERY good to know........thanks a million guys.
All this being said, I find the U46DJ to be a SPECTACULAR soundcard. at about 50% gain
the mixer was way into the red. It seems to have more punch than my Audigy Creative cards
I used to have!!
I used to have!!
geposted Tue 05 Dec 06 @ 5:57 pm
