Hello VDJ community,
Today i got my ESI U46DJ and it works perfect with the 1.16 driver.
I only have one problem and that is that i can't get the quality of timecode to 100% and i think it's because the gain is to high.
I have the silence bar to it's maximum and the gain to it's minimum but i still can't auto setup the stuff.
I'm using a Pioneer CDJ-800MK2 as CD-player with the timecoded CD (Downloaded from this site) and when i scratch, the music is scratching too, so everything works but not at full quality because i can't auto setup it...
Is there a solution to fix this (for example lowering the input gain, but how?)
I hope you guys can help me out :)
geposted Fri 08 Dec 06 @ 12:35 am
i think you can try burning the tccd at a lower gain, i know it was posted on here before
geposted Fri 08 Dec 06 @ 1:15 am
