Forum: VirtualDJ Skins
Topic: Browser problem
With our multi instance skin, we don't want a browser in the 2nd part. This said, if you reload the 2nd instance of the skin the search box jumps up at position x=0, y=0. Is there any way to prevent this, other than putting the browser script in the file but off the screen? If we do this, it is possible to crash VDJ by hitting <shift+tab> (browser switch keyboard shortcut)
Please help!
DJ Mykel
DJ Format
geposted Sat 16 Dec 06 @ 8:13 am
multi instance
you place the browser in a pannel that's not vissible.
cool, thanks
djjb, you are todays top genius, problem solved.
BIG thanks
DJ Mykel
