Topic: Vdj magic? [crash SOLVED => bad mp3]
xgl_djPRO InfinityMember since 2004
I just took a break for studies and decided to mess around for a bit with vdj – I was mixing using just mouse and keyboard(no vinyl control or special effects) for about 30 mins - I dragged a song to the deck and vdj just disappeared from the screen without any error messages. Running a Celeron p2.5 w/512megs and vdj 4.1. Maybe vdj was trying to tell me to get back to my studies but – that was just a weird crash – just needed to report that...
geposted Mon 18 Dec 06 @ 11:13 am
sbangsPRO InfinityMember since 2004
see if it happens again if so let us know
every program will crash from time to time
its all thanks to the os ;) mac/windows that is
geposted Mon 18 Dec 06 @ 11:18 am
Yeah every program crashes.. but the point was, it just disappeared...it didn't have the smiley face box that says fatal error etc... I won't blame the os on this one though...I got my windows trouble free.
geposted Mon 18 Dec 06 @ 11:28 am
does it do it again?
if not i wouldnt worry about it :)
geposted Mon 18 Dec 06 @ 12:55 pm
djcelPRO InfinityModeratorMember since 2004
@xgl_dj
Thank for the report. Certainly a corrupted file. See my private message.
@All users
if you find a file which can do the same thing ONLY on VirtualDJ v4.1 r2 (=closing the software without crashguard), write it here as you can help.
geposted Mon 18 Dec 06 @ 2:21 pm
Will do. I have under 60 files on that pc so I'll check it out - and do what your pm requires. Also I am still using 4.1 not 4.1r2 - so I guess I'll update after I find which file is causing the problem.
geposted Mon 18 Dec 06 @ 3:57 pm
After some testing, it appears the problem comes from the skin used by xgl_dj and it was not a corrupted file
The skin is : V4 D1 (1024x768)(1280x800) by phillydj
So be carefull !!!
I hope it will be corrected by phillydj or the dev staff
Thanks for the help of xgl_dj
geposted Wed 20 Dec 06 @ 8:06 pm
erxonPRO InfinityMember since 2003
So be carefull !!!
Can you explain what kind of XML code made the software crash?
geposted Wed 20 Dec 06 @ 8:19 pm
For the moment we don't know but we are investigating. The crash could be described like that:
* you have this skin
* you load a "specific" but not corrupted song
Now we have to find why with this song (and not others) and why with this skin.
So my advice is not to use these skins currently ;-)
geposted Wed 20 Dec 06 @ 8:25 pm
Well it appears it's not the only skin to crash with this song so use the default skin until we give you the list of these skins or find a fix
geposted Wed 20 Dec 06 @ 8:40 pm
Grrr after a lot of tests, guess what, the problem comes from the comment field in the ID3Tags of the track !!!!! It looks like empty whereas it was not the case.
Topic closed
geposted Fri 22 Dec 06 @ 12:13 am
