I was tild by some frinds that this is good program so I downloade the free version befor I bought so that i could try it out. But when I try to open the program I get this Warning the skin you are trying to use has a higher resolution than you sreen. What should I do?
geposted Sun 24 Dec 06 @ 10:29 am
what Resolution is your screen set at?
geposted Sun 24 Dec 06 @ 1:09 pm
Sky I am thinkin he is at 800X600. Make sure your desktop is at 1024X786 and all will be fine.
geposted Sun 24 Dec 06 @ 10:18 pm
if that still fails its possible you have a currupt internal database
try a reinstal :)
try a reinstal :)
geposted Sun 24 Dec 06 @ 10:19 pm
i have a currpt internal database and a resolution problem...it erased all my bpm...what do i do?
geposted Tue 26 Dec 06 @ 8:00 am
reinstal
geposted Tue 26 Dec 06 @ 12:58 pm
Actually I think there is a bug. Sometimes I get that messege, eventhough my screen resolution is higher then that of the skin. It happens when upon launch, VDJ can't find the selected soundcard and tries to display a messege in a window. It happens when previous session was in full screen mode.
Usually I have to do ALT-TAB untill I get the "soundcard not found" messege and click OK. After that, VDJ comes up fine.
geposted Tue 26 Dec 06 @ 8:03 pm
