Topic: 4.2 & 4.1 Trial Closes Program
I have tried both & it will close after a very short time playing a music video. Numarks Cue did not do that and it's 4.1. One thing i noticed that when i downloaded 4.2 it had said that it only had 4 days left on it. 4.1 said it had -0- days left and i had just downloded it. Whats up. I could'nt buy and have a software do that to me when i'm playing for 200 hundred people. I need a stable software.
geposted Tue 02 Jan 07 @ 9:14 pm
i suggest you remove all the expired versions
and any other versions you may have been using
and get one copy of the demo
i would aslo recomend you dont use demo copies of the software live!
with out testing on your machine
Also when removing the software get rid of it as well in your registry.
ANd too increase reliability to 100%
Purchase the software
You can try all day long to get around the 20-day limit but it's pretty useless and futile.
Since CUE and VirtualDJ are the same engines your 20-days started with the CUE install and you (I am pretty sure) won't get another 20-days by installing VirtualDJ's demo. Now if you are interested and serious about purchasing there have been occasions when you can get an extension by making your request here ( http://www.virtualdj.com/contact/ ).
Good Luck.
i'm still holding out for the christmas discount........lol
