Topic: VDJ PRO quick question
I have a banquet hall that i use vdj dj concole at. I would like to upgrade to pro. I need to have at the hall and at home to practice, playlist, and such. Can I install It on both of my computers without buying it twice?
Thanks, Dj CornDogg
geposted Sat 06 Jan 07 @ 1:26 am
When you buy the pro version, you can use it on more than one computer, as long as you are the sole user of the software. I.e...don't pass it round all your mates and give them serial number for their computers.
To install on more than one machine, burn the download you get onto a cd...and hey presto. Stick it in another cd rom and install.
If you have already analysed a library full of songs, copy your mp3.xml and VDJ Database.xml (User) to your other machine as well...and you'll keep all your bpm's and cues and stuff.
Cheers...and keep spinnin'...(",)
P
I Have been using VDJ for a long while now, and I am a huge fan (as nothing even compares), and this is a big reason why. Friendly fast responces and lots of help. Never would I promote piracy. Thanks for the info Pionara.
Anytime...:o)
P
