Im interested in splitting deck A to channel 1, and deck B to channel 2. I've tried everything and nothing seems to work. Is this possible, or am I just waisting my time? And I do have a 4 channel mixer with pro VDJ. I've tried so many configs , It looked like the way to go was to use the 3 line mixer option. But everytime I tried , It told me I did'nt have enough channels.
geposted Mon 08 Jan 07 @ 4:54 am
under settings/soundcard Did you try changing the outputs: external mixer?
geposted Mon 08 Jan 07 @ 5:01 am
Do you mean ,if I tried clicking the external mixer button on the MK2 ADVANCED SETTING TAB? I did , if that's what you meant.
geposted Mon 08 Jan 07 @ 5:05 am
Depending on the VDJ skin your using Look for Config button/settings/soundcard
geposted Mon 08 Jan 07 @ 5:15 am
Yes , I did try that but it was'nt splitting the MK2 decks , atleast not the way I want it. I basically want each deck to to put out it's own output. You understand , like turning one side off almost. cause I think 1/2 & 3/4 outputs are bridged and then the main output is 1/2. you understand what I mean?
geposted Mon 08 Jan 07 @ 5:33 am
I've split the channels before I'm going to check it out ,, In the mean time is the mk2 set to (DJ)
geposted Mon 08 Jan 07 @ 5:38 am
From the top….
Mk line 1&2 to mixer line in
Mk line 3&4 to mixer line in
Sound card settings: inputs; none , Output: external mixer , Sound card; DJC
Output channels; Left 1&2 - Right 3&4
External mixer put slide pods up and use cross fader on mk
That should do it
That should do it
geposted Mon 08 Jan 07 @ 5:49 am
It's ready to use I just have to connect the USB to my laptop.
geposted Mon 08 Jan 07 @ 5:52 am
Did you download the latest drivers from Hercules.com and the latest mapper?
geposted Mon 08 Jan 07 @ 5:54 am
direct x, 2006 drivers, 4.2r1 everything works beautiful no problems whatsoever.
geposted Mon 08 Jan 07 @ 5:58 am
Did you update the latest drivers from Hercules.com and the latest mapper from vdj?
geposted Mon 08 Jan 07 @ 6:00 am
Yes
geposted Mon 08 Jan 07 @ 6:04 am
Go to effects,, external devices,, do you have (djc)
Did you delete the old mapper?
geposted Mon 08 Jan 07 @ 6:10 am
Never had the old mapper
geposted Mon 08 Jan 07 @ 6:12 am
did you install the Mapper in Vdj Folder/Plugins/Control Divices?
geposted Mon 08 Jan 07 @ 6:16 am
Yes
geposted Mon 08 Jan 07 @ 6:18 am
HKNYC wrote :
Yes
I’m sorry I couldn’t help.. These settings work for me. I don’t believe I mist anything.
Scroll down Tutorials and you’ll find some info
https://virtualdj.com/blog/skyfxl/?category=2
geposted Mon 08 Jan 07 @ 6:21 am
just to confirm
that you have it like this
external mixer mode
4.2 vdj
external mixer on mk2 contol pannel
now if thats the case on the mk2 control pannel , choose mode "asio"
now on vdj choose card "asio"
driver : mk2
and on proformances choose latency = "auto"
what happens now :)?
external mixer mode
4.2 vdj
driver : mk2
geposted Mon 08 Jan 07 @ 11:19 am
hi skyfxl,, Did I miss something.??
geposted Mon 08 Jan 07 @ 4:59 pm
u did a good job :)
when folks have an issue like this one
its always good to try the asio mode
geposted Mon 08 Jan 07 @ 6:22 pm
