Forum: Old versions
Topic: SPLIT MK2 DECKS - Page: 3
the channels are in the cards
the mk2 has 2 out not 3 out
so you need another card with single out aslo for 3 line
you need 3 line because 2 are used as mixing
and
one is used for preview =)
my specs are as follows Toshiba s1415 2.0ghz celeron processor 512mb
in my techy experiance as a support technican
celeron processors have issues with multimedia , but that should be ok
however
thats a small amount of ram its possible the bad noises are because your pcs resources are overstrained
i would recomend a upgrade to 1 or 2 gig if possible aslo try some of the tuneup advice here
https://virtualdj.com/forums/62907/Software_Technical_Support/Asorted_Software_Guides__(common_fixes_and_tweaks_and_how_2_s).html
focus on the ram and virtual memory and xp tweaks :)
Regards Simon :)
do u still need help w/ this chapter?
all help is always apretiated
