when i go to start up virtual DJ it wont let me and it comes up THE CONTROLER HAS NOT BEEN DETECTED. PLEASE PLUG THE CONTROLER AND START VIRTUALDJ AGAIN. what should i do to be able to go on virtual DJ please get back to me asap please thank you .
geposted Mon 15 Jan 07 @ 12:00 am
please reinstall the console drivers
and ensure you have the latest update for them
http://ts.hercules.com/eng/index.php
as this message means the driver is missing or at fault
geposted Mon 15 Jan 07 @ 12:14 am
Is the MK2 plugged in?? Did you unplug it and plug it into a different port. If so that could be the problem. Sounds like you need to re-install the MK2 drivers then try to start VDJ. It is very important that you only plug the MK2 into the same USB slot each time or you will have to reinstall the drivers again and again.
Sky we typed that at the same time lol.
geposted Mon 15 Jan 07 @ 12:15 am
lol , ;)
22 seconds to slow =)
geposted Mon 15 Jan 07 @ 12:18 am
