Topic: WHY???????
It’s a pain in the A S S to figure out what skin has been added or updated….
Your able to sort Video effects, samples, Plugins, Sound Effects by date, downloads or stares.
Is this something that could be made search friendly
geposted Mon 22 Jan 07 @ 9:14 pm
Absolutely right !
Make a separate list for skins for 4.0 and above, and leave the users to say how many stars they should have. Update date is the most important and not the stars
skins that are for 4 pro are marked as such , and as to the updates click on a skin and
yonder info apears
for example .
Date added: Mon 4 Sep 06
Last update: Mon 4 Sep 06
Created for VirtualDJ version 4.0
if you want to have the updated skins ONLY, then you have to check ALL the skins. That's waste of time.
If you could sort them by date, and the date appeard next to the version for example, this could be usefull.
If a Skin is add or updated,, It moves to the top of the list.. You can’t tell what skin or skins have been updated…
Yes skyfxl, if you open each and every link under info appears for example .
But you need to open each and every link …
Infect, didn’t it use to have that info on the skin page right under the skin??
Great idea :)) Don't ignore this one!!
dj t boogie wrote :
i think this needs to be addressed a.s.a.p. ;
Yes, I agree! It needs to be similar to how the Plug-ins are displayed. (And you should be able to choose how you want to sort the information.)
I suggested to the Web-team to create a RSS feed that would show all news relative to VDJ, and also all new addons.
I thinks this would be the best way to know when there is a new skin, and what's new about VDJ.
nice, i like the rss idea
