Since I could not find anything when I searched (maybe because its a stupid question) here goes. I have many files that are in WMA format. I would like to change them to mp3 or wav. Is there an audio conversion tool that will help me do so? If someone tells me I just change the file extension then I'll be embarrassed. I'm at work and don't have the files with me to test that. I would thihk you couldn't though. Thanks.
geposted Fri 26 Jan 07 @ 4:25 pm
once you have put them into wma alot of the bitrate and quality is gone you cannot put back what has been removed:(
you can try this program but it wont increase quality it will have to be at the same or similar bitrate as the wma
http://www.google.co.uk/pagead/iclk?sa=l&ai=BKfuQWh-6RYCfHZiqQPue9a8DotfSH-CU4aMB8PanlAPwkwkIABABGAEoAjgAUIDKk_H7_____wFgu76ug9AKmAGdkgagAdLZkP8DyAEBgAIByALG_1s&adurl=http://www.smartaudioconverter.com%3Fid%3Dsacgg
geposted Fri 26 Jan 07 @ 4:34 pm
Most of creative soundcard products come with an audio conversion utility.
Works well.
DJ Marcel
Works well.
DJ Marcel
geposted Fri 26 Jan 07 @ 6:36 pm
Thanks folks. Actually one of my soundcards is Creative so I have some of there software, I'll take a look. I have to take a closer look at the files that are WMA, I don't know where I got them from. I usually make certain to use mp3 and at minimum 192kbps. Usually 256. Off hand, I'm thinking they may be tracks I got off Napster.
geposted Fri 26 Jan 07 @ 8:56 pm
Try Tunebite. It'll "record" iTunes and WMA files to MP3. I use it all the time.
geposted Wed 31 Jan 07 @ 12:12 pm
I don't know if you've ever heard of this, but I've found Jodix to be quite a good program. It's freeware, EXTREMELY easy to use, can change bundles of tracks at a time...although I wouldn't load up more than 300 - this seemed to cause problems for me...and is relatively quick. It has no spyware, adware, viruses or anything like that at all.
You can select how you want the files to be ripped (up to 320kbps for mp3 i believe) using either a set bit rate or a variable bit rate (although VBR is not recommended). It also works with some video files but if you check out the website link above you can get all the more information on there.
It's only a tiny wee install program and you can do other 'normal' tasks when it's running. It can be minimised to the toolbar as well so it's out the way for you to continue working.
Napster tunes and other downloaded material should be burnt to cd and re-ripped as an MP3 (I use Windows Media Player to do this) and then you'll find that all your downloads will work on VDJ. That way you'll also have a cd back up in case anything goes wrong.
I've just used it to convert about 8,500 wma's to mp3 and I've had no issues - apart from maybe one or two songs not working and an apparent limit of 300 tracks at a time...but you get the idea.
Good luck!
P
Good luck!
P
geposted Wed 31 Jan 07 @ 12:38 pm
