Topic: yo yo yo
marksyPRO InfinityMember since 2004
JUST GO FULL VERSION YEAH
geposted Wed 18 Aug 04 @ 2:59 am
loool ;)
guess u just bought it by the "yo yo yo" post....
welcome :)
geposted Wed 18 Aug 04 @ 3:13 am
claxPRO InfinityMember since 2004
Welcome aboard guy. Enjoy this soft.
geposted Wed 18 Aug 04 @ 3:30 am
kaleoPRO InfinityMember since 2003
Welcome marksy and goooood mix!
geposted Wed 18 Aug 04 @ 8:53 am
BarglerPRO InfinityMember since 2004
You'll love it.
I haven't regretted buying the full version for a second.
Bargler
geposted Wed 18 Aug 04 @ 10:14 am
me neither ;) so.. ditto that "YO YO YO YO!!" ... lol ;)
geposted Wed 18 Aug 04 @ 10:18 am
clax are u from canada ?
geposted Thu 19 Aug 04 @ 6:02 pm
No I'm from Belgium
geposted Fri 20 Aug 04 @ 4:34 am
this program well.....
its awsome, had mates over last nite they would come down and produce some alright stuff, had the music pumping out my big speakers, we was mixing evering, sum of it sounded poor, but we yet to master, we had , dance, trance, rave, rock, punk, rap
unbelievable fun, and its awsome how u can do it straight from cd, it sorta feels like changing a vinyal but smaller
they only thing i cant understand is keyboard shortcuts, they suck setting them up and then i dont remember them
could anyone help me with them pllzzzzzzz.......!
i just wana be able to do the effects, like have 3 spereate keys for each deck
but yeah
geposted Sat 21 Aug 04 @ 4:19 am
You can adapt shortcuts like you want. You can change the shortcuts and add a lot. You can also put many actions with only a key touch. Try it it's simple.
-- Select the action and push the key you want to assign with this action.
geposted Sat 21 Aug 04 @ 11:30 am
marksy: "i just wana be able to do the effects, like have 3 spereate keys for each deck"
Get a Hercules DJ Console :) Very easy and very straight forward layout, so you won't forget what's what...
geposted Sat 21 Aug 04 @ 2:17 pm
@marksy
Like everything else, you have to spend some time to learn powerful tools. You can't be a success overnight at Djing or using tools, you should take some time to become familar... (practice)
Try labeling your shortcuts. You'll find that after a while, you don't need the lebels, because you would have LEARNED the positions.
geposted Sat 21 Aug 04 @ 5:11 pm
Adding a shortcut is very straight forward : go to the config panel, shortcuts section, click on "add", and hit the key you want to use.
some allready there great keyboard shortcuts:
- f1 to f12: samples
- "1" to "9" : loop on active deck from 1/4 to 64 beats
- "P" : play on active deck
- "s" : stop on active deck
- "tab" : switch active deck
- "b" : beatlock active deck
- "page up/down" : move crossfader
- arrows : nudge song to fit beat
- spacebar : sync beat
some I have made myself:
- mute
- effects (1-2-3)
you can make these by adding shortcuts (one or more) to a specific key...
geposted Sat 21 Aug 04 @ 5:50 pm
thanks for the input,
ive tried making shortcuts, i still need time to get it all,
ive use to use traktor and i made heaps of shortcuts on that and i could remember them all,
but my main prob is
when i try to make shortcut for effects, have 3 different keys for each deck, i know how to allocate the key and all, i just cant find the spot were it says sfor the efects 1,2,3
it says all this other junk in the effects part of the shortcut adding
arhharhrahr
i`ll get it soon
cheers ppeople
geposted Sun 22 Aug 04 @ 11:34 am
djzeroPRO InfinityMember since 2003
just find the bit that says effects and then as the value property type 1,2,3 etc and you will get that effect... it is very easy onve you fidure out the initial steps
geposted Sun 22 Aug 04 @ 12:34 pm
i got it, i did what u said i think and played around and firgured it out all by myself.... shoot it was hard it was staring me right in the face! dont u just hate that???, thanks for all the help everyone, ive now got 12songs which ive been practising mixing and going to record, hopefully i wont forget what to do, i probs will hahahahah,
and i was like later dudes
geposted Wed 25 Aug 04 @ 8:30 am
