Hi,
Could you please tell me how I can play VDJ so the sound comes out from the headphone jack on my laptop?
Currently, when I play the audio on my laptop in WIndows Media Player, the sound comes out the headphone jack whih is plugged into speakers
When I play VDJ with the cords the same, the sound does not come out the headphone jack to the speakers. Instead I just hear it on the lappy's speakers.
thanks,
B
thanks,
B
geposted Tue 06 Feb 07 @ 6:46 pm
Go into the config, choose the sound tab and make sure that the correct soundcard and sound config options are set in vdj.
geposted Tue 06 Feb 07 @ 6:48 pm
the soundcard selected in the options should match the one listed in your pc's hardware profile
geposted Tue 06 Feb 07 @ 7:51 pm
