Just a question for ye,
I ordered the timecode vinyls from this site 6 weeks ago and still haven't received them, also i was charged twice for them. Nobody has responded to my tickets. Have any of ye had this problem.
Thanks,
Dricco.
Thanks,
Dricco.
geposted Thu 15 Feb 07 @ 3:21 pm
apolgies for the delay all of the vdj staff have been at siel for the last few days ,
they will be getting back to folks asp :)
geposted Thu 15 Feb 07 @ 5:06 pm
how come you order TCV, but seem to not own VDJ.. Or did you forget to enter your serial..
geposted Fri 16 Feb 07 @ 2:32 am
I goin using djdecks software. It's free and supports virtual dj timecode vinyls. I'm a poor student and can't afford virtual dj yet.
thanks,
Cian
thanks,
Cian
geposted Sat 17 Feb 07 @ 8:59 pm
are dj decks alowed to do that?
geposted Sat 17 Feb 07 @ 9:53 pm
Why not? - Virtual DJ supports Serato Vinals
geposted Sat 17 Feb 07 @ 11:22 pm
true true
only thing going for dj decks tho is its very cheap lol
geposted Sat 17 Feb 07 @ 11:24 pm
When are the TCVs gonna be available to order?? just went to go order a set of 2, but it says Out Of Stock!!
geposted Sun 18 Feb 07 @ 12:55 am
soon as possible remember gen 3 has just come in to existance :)
geposted Sun 18 Feb 07 @ 1:12 am
Sorry but it's wrong. Only the serato sound card !!
geposted Sun 18 Feb 07 @ 1:28 pm
my bad
oops
oops
geposted Sun 18 Feb 07 @ 3:52 pm
why cant they just add support for SSL vinyls, will make it easier for SSL switchers if they can use their own vinyl
geposted Sun 18 Feb 07 @ 4:56 pm
Because you need to have their timecoded algorithm "open source" in order to use their vinyls.
geposted Sun 18 Feb 07 @ 6:05 pm
i thought we did support it but with purposeful limitations ie no needle drop
geposted Sun 18 Feb 07 @ 6:35 pm
No it's wrong and if it "can" work it's just by chance.
geposted Mon 19 Feb 07 @ 12:05 pm
1st.. djDecks is not free. It comes cheap, but is not free..
Second, there's much better TCV which you can use with djDecks, SSL/FS/msPinky are all better IMO. And at least FS vinyl can be bought off the shelf in most countries afaik..
geposted Tue 20 Feb 07 @ 6:10 pm
i think you need to check out the new gen 3 timecoded records now with a browser track ;) and many new features
geposted Tue 20 Feb 07 @ 6:38 pm
My SSL TCVs have a 'browser track' and to be honest I hate it..
geposted Tue 20 Feb 07 @ 6:41 pm
it doesnt need to be open source....reverse engineering for the purpose of compatibility is allowed. hence the fact that DJ Decks is fully compatible with many and is breaking no laws.
even so. the 6% thing can be got around witout having to set your turntable different. just pitch reset on the skin in VDJ (or press '*' on the num pad-by default) and VDJ will carry on as if the deck is at normal speed, matching and syncing effects etc correctly.
this wont stop the stupid pitch reset problem when the timecode runs out (DOH) or if you go to 'internal mode'.............but hey, they know about that and its getting sorted in the next update, rite?
geposted Wed 21 Feb 07 @ 12:24 am
Hi, I managed to sort the charged twice thing myself. Was the credit card companies fault but nobody has replied to my ticket. It's been there for 2 weeks now and it says it hasn't even been read. It is starting to be a bit of a joke now. I order my TCV at the start of Jan. Has anybody else had this problem or does anybody have an e-mail address so i can contact the company directly.
geposted Wed 28 Feb 07 @ 4:40 pm
