Topic: PROJECTOR?????
I want to know how can i see the the music video on the projector just the video not the mixer. THANK YOU........... i Currently have a Compaq notebook 6110x (laptop).
geposted Fri 16 Feb 07 @ 7:55 am
you should have the ability to have two monitor support in your desktop settings. Not too sure what to do other than just enable that, it should be easy after you do that.
geposted Fri 16 Feb 07 @ 8:19 am
NiemsPRO InfinityMember since 2006
Find the option in display properties > settings that says "extend windows desktop onto this monitor" while you have the 2nd display selected. Then drag the video window onto the projector side.
geposted Fri 16 Feb 07 @ 12:06 pm
PionaraPRO InfinityMember since 2004
In display properties, make sure you have 2nd device set to 'attached', then, from VDJ ensure that you have your graphics card selected as output rather than 'Window'.
Keep spinnin'...(",)
P
geposted Fri 16 Feb 07 @ 1:33 pm
I think that your laptop does not support secondary monitor because you don't have second VGA outup. But you may have video SVHS out. Check this and feedback please.
geposted Fri 16 Feb 07 @ 5:59 pm
