Forum: Old versions
Topic: VISTA problem with karaoke zip
I recently upgraded to Windows Vista, I mainly use VJ for Karaoke gig I have tons of CDG zip files but after installing VJ into vista and configure the codec for zip as karaoke it read as Folder only not as files
unlike on winxp runs sweet
Please help
Thanks
geposted Thu 22 Feb 07 @ 9:08 pm
the console version is not compatable with vista yet we are waiting on a patch
so A ur using the Demo
or b you have a crack
i recommned you wait for the correct patches from herc
I am not using a Demo version or a crack version or console
and am using an icdx that I bought a month ago
anyway I dont think you understand the question,
I am Have been running this in Windows XP and works awesome, yes I use mp3 for DJing and but I also use the karaoke feature wich can play cdg and zip karaoke, this is common and works awesome in xp now I upgraded to windows Vista and now reading zip as folder instead of files so I cannot play it.
thanks
You are using the console version and as Sky said it is not compatible with Vista yet.
so did you guys got the zip karaoke running on vista?
OK here a easy one ? for you guys I use this Program 6 nights a week and need your Help
i would like to know if there a way to Input Singer Name for the Karaoke Side. The DJ Side rock 100% if you guys can find a way so we can input the name of the next sing it would make this so Sweet I have 6-7 DJ that are using SAX & DOTTY and would buy VDJ if it did Karaoke and DJ from the same Program I know that Sax & dotty are Coming out with a All in one Karaoke and DJ program called Show hoster plays CD+G and Mp3's and Video also i have a Demo of it here looks Cool Still love VDJ or even a plugin for this works for me later and keep up the good work
DJ Jim Patrick
owner
laser Tunes Dj service
middletown ohio
45044
jpatrick29@sprintpcs.com
www.myspace.com/DJJIM65
I am having the exact same problem as JR8... with pro version. What gives?
same problem for me!
@ dj j/j
you could use dj cels new text2d to show who your next singer(s) will be and its got some great scrolling features as well as different colour combinations that you could utilise, if you hav'nt already seen it check it out in the pluggin section. mind its still in the beta stage but as yet i have not encountered any problems hope its what your looking for....
Tayla
