I need to replace my MOTHERBOARD and I could us all the help I can get ... I running MP3's, karaoke and looking into video...
I have the following hardware to be integrate onto the board..
Processor
Intel Pentium® 4 631 Processor Prescott 3.0GHz, 800MHz FSB, Socket 775, 2MB
Ram
OCZ OCZ28002048ELDCGE-K 2GB Kit DDR2-800 PC2-6400 Enhanced Latency Gold Edition Dual Channel Memory
Video Card
Sapphire Radeon X1600 PRO PCI Express 512MB DDR2 Video Card w/TV-Out, DVI & VGA
I would like to keep the coast down and quality up so please post ideas and links, no ebay links or check these out please, just specific boards.
I have a strong power supply & a nice case to put the board into...
Thanks
Processor
Ram
Video Card
Thanks
geposted Sun 04 Mar 07 @ 1:07 am
You didn't say micro - regualr ATX
Here are 2 That I would consider
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2366120&CatId=1572
And the Second
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2315790&CatId=1572
Your Memory is Quite Fast and to take full advantage of that you mmight want to pay a little more than these two examples cost they're ram clock speed is slightly slower than yours is - usable just a little slower.
Thes are from a Canadian Website but Tiger direct should have an americian board - they're world wide.
Good Luck and Don't run your Credit Card up too much
DJ Marcel
Purple Onion NightClub
And the Second
DJ Marcel
geposted Sun 04 Mar 07 @ 2:12 am
You have add more ram memory to make more better performace.
Try to upgrade your ram by 2Gb.... Im using 2Gb i dont have a problem in video motion. . .
geposted Sun 04 Mar 07 @ 11:42 am
And the Secondhttp://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2315790&CatId=1572
DJ Marcel
DJ Marcel
geposted Sun 04 Mar 07 @ 8:51 pm
