Topic: Motherboard needed
I need to replace my MOTHERBOARD and I could us all the help I can get ... I running MP3's, karaoke and looking into video...
I have the following hardware to be integrate onto the board..
Processor
Intel Pentium® 4 631 Processor Prescott 3.0GHz, 800MHz FSB, Socket 775, 2MB
Ram
OCZ OCZ28002048ELDCGE-K 2GB Kit DDR2-800 PC2-6400 Enhanced Latency Gold Edition Dual Channel Memory
Video Card
Sapphire Radeon X1600 PRO PCI Express 512MB DDR2 Video Card w/TV-Out, DVI & VGA
I would like to keep the coast down and quality up so please post ideas and links, no ebay links or check these out please, just specific boards.
I have a strong power supply & a nice case to put the board into...
Thanks
geposted Sun 04 Mar 07 @ 1:07 am
You didn't say micro - regualr ATX
Here are 2 That I would consider
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2366120&CatId=1572
And the Second
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2315790&CatId=1572
Your Memory is Quite Fast and to take full advantage of that you mmight want to pay a little more than these two examples cost they're ram clock speed is slightly slower than yours is - usable just a little slower.
Thes are from a Canadian Website but Tiger direct should have an americian board - they're world wide.
Good Luck and Don't run your Credit Card up too much
DJ Marcel
Purple Onion NightClub
You have add more ram memory to make more better performace.
Try to upgrade your ram by 2Gb.... Im using 2Gb i dont have a problem in video motion. . .
