| Autor | - Topic: Can these work in VDJ? - |
I was thumbing through my bookmarks and came across one I had not loaded in a while. I think I was looking for transition plug-ins for Sony's Vegas program, but VDJ is also listed as a program that supports this plug-in type. Can any developer verify? Here are the links: http://freeframe.sourceforge.net/downloads.html http://www.vjfx.com/vjfx_store_sys.php?op=VJFXStore A lot of the plug-ins (well just about all of them) on the VJFX site look kick-ass. |
Hi, Yeah, not all of them work, but most of them, download "pete's plugins", you'll be amazed at the effects if you like doing video! Should mention, these arn't transitions though, just effects (like kalidascope, blur, etc) you can add to the vido. :) |
Yes Virtual DJ internally supports Freeframe plugins ;-) |
