i looked in effects yet the one i found said "useless with VDJ 4.x. Could you please send me a link for the key changer...thanks. Michael
geposted Thu 22 Mar 07 @ 12:20 am
guys i think I've found it... just need to make sure I am using it correctly.
when I desire to use the key changer....
load song in deck 1 (for example) , then click effects , choose Key Changer and activate the appropriate deck , choose the requested key change (is it in half notes?) and when i play the song, it will stay at its original bmp, but the key will change>
there is a small Key tab right above my pitch slider, in Vmix skin. Do I do anything here... it looks like a Lock (or unlock) Just wondering . I don't use key changer a lot but it is requested about three times a night. Thanks Michael
geposted Thu 22 Mar 07 @ 12:44 am
Keychanger uses in fact the function key_offset() of VirtualDJ
geposted Thu 22 Mar 07 @ 12:55 am
Please explain offset function key... thanks
geposted Fri 23 Mar 07 @ 9:24 pm
