my laptop went nighty night and and have a wedding tomarrow day and a club nite right afterwards... I was going to use my pc for future shows anyway... last night i realized that my pc vdj is corrupt on my pc from the trial days... luckily have all my music backed up on external drive.
from what i gathered from the forums. i could use a tool to correct the data or is it just for pro users?
the corruption is on data that was on music that was just on the drive... could i right click on local and delete drive... then reanylize the new drive.
i really dont want the data on that drive anyway.
i unistalled the software / reinstalled
thnx for the advise
thnx for the advise
geposted Fri 23 Mar 07 @ 5:58 pm
if you don't want the data and you've did a fresh install ...then yes i would recommend adding the xternal drive and doing a full scan of all your music.
geposted Fri 23 Mar 07 @ 8:56 pm
thanks for the response, but can I delete the data folder to get rid of the music file listed then do a anylization of new songs.
geposted Sat 24 Mar 07 @ 12:41 am
when you say data ..you mean the music / if so then yes
geposted Sat 24 Mar 07 @ 3:36 am
