Hi to all,
I've got a simple question for you...I've just downloaded the trial version of VirtualDJ as I want to try it and if good then eventually buy it...can you tell me which are the differences btw the trial version and the complete version? I mean, are there any features that are not in use in the trial version?
I'd like also to know if there are any features that may stop the system or cause some problems...I would like to try the VDJ live during a clubbing night, but I need to know if it will caus me some problem, as it is not the complete version...
thank you in advance for any answer.
p.
p.
geposted Mon 26 Mar 07 @ 9:13 pm
There is nothing that will stop you from using the software, but low machine specs. I hope you try this at home first, because you should not use your clients as beta testers. Now, video is another animal, as you will need a good video card to use the trial or registered version. enjoy.
geposted Mon 26 Mar 07 @ 9:18 pm
I thought that video output is not available in the trial version. Am i wrong?
geposted Tue 27 Mar 07 @ 4:50 pm
trials are now full for 20 days,.
geposted Tue 27 Mar 07 @ 4:52 pm
So this means FULL FEATURES (as VirtualDJ Pro), but limited to 20 days.
geposted Tue 27 Mar 07 @ 4:55 pm
yes :)
geposted Tue 27 Mar 07 @ 4:56 pm
Is that calander days or 20 uses?
geposted Tue 27 Mar 07 @ 9:09 pm
solar calander days.
geposted Tue 27 Mar 07 @ 10:20 pm
