My DAC 3 just stopped functioning. It was working fine for 2 plus hours, but then bam. The lights and display still work, but none of the controls function. I changed the cable, and no go. I' using JPs 1.4 mapper. Any ideas?
geposted Tue 27 Mar 07 @ 9:35 pm
bump
geposted Wed 28 Mar 07 @ 12:35 am
Can you start the player with the mouse Rick?
Friend of mine in Jamaica had this issue with a bad board usb connection.
Had to solder it and it was fine.
Try deselect, close, reopen and select again.
geposted Wed 28 Mar 07 @ 1:24 am
Did all that. Fortunately, I am very good with the mouse, but made a few mistakes, trying to use the controller. I forgot it wasn't working. I had to take the controller from in front of me, because I kept trying to use it. As I said before, VDJ kept working, and the display on the controller, an the lights also worked. It's just that none of the buttons or controls responded. I believe it may be the usb port, that it's worn out. I just replaced my motherboard, for the same reason. Plugging and unplugging, twice a day, 5 to 7 days a week, for almost three years(June). It takes a toll. I'm starting to use powered usb hubs, so they may last awhile. I'm home now, and guess what, it works. .
geposted Wed 28 Mar 07 @ 5:32 am
PARTY AT RICKS HOUSE!
geposted Wed 28 Mar 07 @ 11:41 am
on my way lol
geposted Wed 28 Mar 07 @ 2:53 pm
