Forum: VirtualDJ Skins
Topic: Turntablist 1.3(1280x768) (1440x900_beta) - Page: 2
k_onePRO InfinityMember since 2006
Yeah that would be great!
Would cater tho all those using a MacBook (or any other PC with 13" screen)
geposted Tue 05 Feb 08 @ 6:52 pm
listen2PRO InfinityMember since 2005
No problem, for me i just like to see the taskbar while i mix.
geposted Wed 06 Feb 08 @ 9:56 am
Could you possibly post the ZIP file directly as well? Makes it easier for us MAC users ;)
geposted Wed 06 Feb 08 @ 4:47 pm
giestoPRO InfinityMember since 2006
I love this skin, only one thing missing having the option of changing from scratch to jog on the mini turntable... unless I've missed a button or keyboard shortcut?
Having more control of the turntable would be a fantastic addition to this skin, useful for when you want to create new cue points.
Thanks
Mark
geposted Tue 12 Feb 08 @ 7:46 pm
bonjour je recherche quel qu un qui pourrai me cree un skin virtual dj .
car j ai essayer mais pas moyen merci.
geposted Wed 13 Feb 08 @ 5:53 am
Thanks! ( i think) :)
you can select a few more cue points by using the 1,2,3 buttons to set hot cue points. The reason the turntable or spinner does not have any function is because it was never designed to be used without timecoded vinyl. I believe you can always set a shortcut to add a function that the skin does not have by default. I could always add something in for you also but it would not be added as a new default on the skin.
geposted Wed 13 Feb 08 @ 1:15 pm
could use a smaller version as well - 13 in lappy
geposted Mon 18 Feb 08 @ 3:27 pm
or did you already? my fav. skin... all i need is the smaller resolution
thanks
geposted Mon 18 Feb 08 @ 4:00 pm
vgarciaHome userMember since 2007
could any one please resize skin to 1280x800.. please =]
email: vgarcia25
or just post here thanks
x]
geposted Wed 20 Feb 08 @ 1:14 am
@lamont76: i have a smaller 1024x800 version it still needs some touch up/fixes but i think most of it just small graphic adjustments. If you want i can send it to you to test.
@vgarcia: the skin is for registered pro users only, sorry.
geposted Wed 20 Feb 08 @ 8:02 am
what if i say pretty please
geposted Wed 20 Feb 08 @ 12:48 pm
sbangsPRO InfinityMember since 2004
It relies on functionality only included in full Cue so it wouldn't work with LE.
geposted Wed 20 Feb 08 @ 3:08 pm
I hate to sound impatient, but when do you think you'll have the 1280x800 ready?
geposted Thu 21 Feb 08 @ 3:30 pm
For that little bit you better off just pressing the maximize button and --- poof! you got a 1280x800 skin. :)
I did try but if i extend the browser section like you want at 800 i lose the very top of the waves section because they used the graphics down there for my top of my splt wave display. So i would have to move everything included. Did you try hitting max and stretching the skin that small amount?
geposted Fri 22 Feb 08 @ 6:11 am
no, I haven't...hehe
I'll give that a try first ;)
geposted Fri 22 Feb 08 @ 8:42 am
hey man, you ever finish resizing that skin?
geposted Wed 05 Mar 08 @ 9:17 pm
