please test this
load and play a song in deck 1, load a song in deck 2 but dont play it. use -16 beats button to go a couple of measures back past the start ('7' on the num pad) and then come back pressing +16 beats ('9' on the num pad) and see if it crashes VDJ.
this hapened to me when i was trying to jump back to a different part of the song on deck 1 but somehow deck 2 had become the active deck (i had manualy selected it previously and it must have trigered back to the stationary deck after a bit of bass had joged the platter and made it think it was the active deck again)
geposted Thu 29 Mar 07 @ 11:12 pm
also, this is a full 'Virtual DJ has performed an illegal operation and needs to close, do you want to send an error report?' type of crash.
the crash does not occur unless using timecode controll
geposted Thu 29 Mar 07 @ 11:27 pm
ok crash confirmed with timecode
geposted Fri 30 Mar 07 @ 1:45 am
another thing for the IN tray of the developer
geposted Fri 30 Mar 07 @ 2:41 am
TCCD problems, and crash . i dunno why!
geposted Thu 12 Apr 07 @ 1:50 am
In your case, maybe the cracked version that you are using !!!!!
geposted Thu 12 Apr 07 @ 2:00 am
if you like the program and want the best results mate please buy pro
that way you get a safe copy with no unstable bugs caused by cracking
kind regards
simon
kind regards
simon
geposted Fri 13 Apr 07 @ 12:41 am
