Forum: Old versions
Topic: Unable to install
My mac don't install vdj, i have the problem with mac library?
I have Tiger 10.4
And my mac don't see the .dmg, when i check to open this.
dj paul Rust
geposted Sat 31 Mar 07 @ 12:32 pm
a dmg is a image file (like .rar or .zip on Windows) try this
Click on the .dmg file> in the Finder go to File> get info> in the pop-up menu go to open with and choose DiskImageMounter> be sure to click on Change All to make this your .dmg default application.
should now load it ?
if you cant see it all , may be a good idea to redownload to another location
inside you will see the mpkg file.
ok in finder check that for the mpkg
"Apple installer " is the defualt program for running these files
Nothing, impossible to install.
I try to download again the image dmg?
I have mac from many years and i expert to use this.
dj Paul Rust
