So far I have 8 Proceszses running
add me to your MSN I have to go pick up the GF from work but I'll come back and help if I can at in about an hour I'll send you a PM with the addy.
geposted Thu 05 Apr 07 @ 4:09 am
How did you format it as it was a C drive, can you stick another drive in a system and will it change the drive letter. Damnit I knew I shouldnt have gotten myself into this mess
geposted Thu 05 Apr 07 @ 4:10 am
When I formated the drive i removed it from the dj system; set the jumpers on the back of the drive to "cable select" and then hooked it up (if IDE) to the secondary IDE connection - hooked up a power cable
1) Turn on the compy
2) select the new hard drive in MY COMPUTER
3) FIle dropdown menu - select format and follow the instructions.
this formats the drive for XP - this is okay cause VISTA will reconise the format - and when you re-install VISTA on a blank XP formated disk - you can re-format it again for VISTA during the install process - MAke sure you chose ADVANCED setup
Don;t worry about the drive "letter" - windows changes that as it needs to according to how many drives/partitions you have
geposted Thu 05 Apr 07 @ 5:37 am
can I take it to another XP machine and re-format it?? I am thinkin now I am going to reformat and go back to XP as my MOBO has no Vista drivers. I can do video I think just no Sonique on Vista. As of now I am tryin a different USB port on the machine for the MK2 I am also gonna try and install the Audio driver as a XP driver. UPDATE found the drivers at NVIDIA we will see how it goes.
geposted Thu 05 Apr 07 @ 6:38 am
Should work.
Yes you can re-format in XP - and go back to XP if you want.
If you don't use the onboard audio I wouldn't worry about it - VIsta will install a generic audio driver and you'll have sound.
That's if you're going to use the MK2 as a soundcard.
geposted Thu 05 Apr 07 @ 7:39 am
I am now havin the same problem as I had with the Dell back in the days. In order to use the MK2 as a soundcard it has to be on Safe Mode. Now I know that isnt right, but I dont see why there are 40 processes runninf and I have no clue what some of them are. I am about to keyboard and mouse dj this week or I am gonna install XP on another drive. This is weird I thought I would jump ahead a little goin to Vista, but I have jumped back.
IRQ 0 System timer OK
IRQ 1 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard OK
IRQ 4 Communications Port (COM1) OK
IRQ 5 NVIDIA nForce PCI System Management OK
IRQ 6 Standard floppy disk controller OK
IRQ 8 System CMOS/real time clock OK
IRQ 10 OK
IRQ 12 PS/2 Compatible Mouse OK
IRQ 13 Numeric data processor OK
IRQ 14 ATA Channel 0 OK
IRQ 15 ATA Channel 1 OK
IRQ 20 Standard Enhanced PCI to USB Host Controller OK
IRQ 21 Realtek AC'97 Audio OK
IRQ 21 Standard Dual Channel PCI IDE Controller OK
IRQ 22 Standard Dual Channel PCI IDE Controller OK
IRQ 22 NVIDIA nForce Networking Controller OK
IRQ 23 Standard OpenHCD USB Host Controller OK
IRQ 80 Microsoft ACPI-Compliant System OK
IRQ 81 Microsoft ACPI-Compliant System OK
IRQ 82 Microsoft ACPI-Compliant System OK
IRQ 83 Microsoft ACPI-Compliant System OK
IRQ 84 Microsoft ACPI-Compliant System OK
IRQ 85 Microsoft ACPI-Compliant System OK
IRQ 86 Microsoft ACPI-Compliant System OK
IRQ 87 Microsoft ACPI-Compliant System OK
IRQ 88 Microsoft ACPI-Compliant System OK
IRQ 89 Microsoft ACPI-Compliant System OK
IRQ 90 Microsoft ACPI-Compliant System OK
IRQ 91 Microsoft ACPI-Compliant System OK
IRQ 92 Microsoft ACPI-Compliant System OK
IRQ 93 Microsoft ACPI-Compliant System OK
IRQ 94 Microsoft ACPI-Compliant System OK
IRQ 95 Microsoft ACPI-Compliant System OK
IRQ 96 Microsoft ACPI-Compliant System OK
IRQ 97 Microsoft ACPI-Compliant System OK
IRQ 98 Microsoft ACPI-Compliant System OK
IRQ 99 Microsoft ACPI-Compliant System OK
IRQ 100 Microsoft ACPI-Compliant System OK
IRQ 101 Microsoft ACPI-Compliant System OK
IRQ 102 Microsoft ACPI-Compliant System OK
IRQ 103 Microsoft ACPI-Compliant System OK
IRQ 104 Microsoft ACPI-Compliant System OK
IRQ 105 Microsoft ACPI-Compliant System OK
IRQ 106 Microsoft ACPI-Compliant System OK
IRQ 107 Microsoft ACPI-Compliant System OK
IRQ 108 Microsoft ACPI-Compliant System OK
IRQ 109 Microsoft ACPI-Compliant System OK
IRQ 110 Microsoft ACPI-Compliant System OK
IRQ 111 Microsoft ACPI-Compliant System OK
IRQ 112 Microsoft ACPI-Compliant System OK
IRQ 113 Microsoft ACPI-Compliant System OK
IRQ 114 Microsoft ACPI-Compliant System OK
IRQ 115 Microsoft ACPI-Compliant System OK
IRQ 116 Microsoft ACPI-Compliant System OK
IRQ 117 Microsoft ACPI-Compliant System OK
IRQ 118 Microsoft ACPI-Compliant System OK
IRQ 119 Microsoft ACPI-Compliant System OK
IRQ 120 Microsoft ACPI-Compliant System OK
IRQ 121 Microsoft ACPI-Compliant System OK
IRQ 122 Microsoft ACPI-Compliant System OK
IRQ 123 Microsoft ACPI-Compliant System OK
IRQ 124 Microsoft ACPI-Compliant System OK
IRQ 125 Microsoft ACPI-Compliant System OK
IRQ 126 Microsoft ACPI-Compliant System OK
IRQ 127 Microsoft ACPI-Compliant System OK
IRQ 128 Microsoft ACPI-Compliant System OK
IRQ 129 Microsoft ACPI-Compliant System OK
IRQ 130 Microsoft ACPI-Compliant System OK
IRQ 131 Microsoft ACPI-Compliant System OK
IRQ 132 Microsoft ACPI-Compliant System OK
IRQ 133 Microsoft ACPI-Compliant System OK
IRQ 134 Microsoft ACPI-Compliant System OK
IRQ 135 Microsoft ACPI-Compliant System OK
IRQ 136 Microsoft ACPI-Compliant System OK
IRQ 137 Microsoft ACPI-Compliant System OK
IRQ 138 Microsoft ACPI-Compliant System OK
IRQ 139 Microsoft ACPI-Compliant System OK
IRQ 140 Microsoft ACPI-Compliant System OK
IRQ 141 Microsoft ACPI-Compliant System OK
IRQ 142 Microsoft ACPI-Compliant System OK
IRQ 143 Microsoft ACPI-Compliant System OK
IRQ 144 Microsoft ACPI-Compliant System OK
IRQ 145 Microsoft ACPI-Compliant System OK
IRQ 146 Microsoft ACPI-Compliant System OK
IRQ 147 Microsoft ACPI-Compliant System OK
IRQ 148 Microsoft ACPI-Compliant System OK
IRQ 149 Microsoft ACPI-Compliant System OK
IRQ 150 Microsoft ACPI-Compliant System OK
IRQ 151 Microsoft ACPI-Compliant System OK
IRQ 152 Microsoft ACPI-Compliant System OK
IRQ 153 Microsoft ACPI-Compliant System OK
IRQ 154 Microsoft ACPI-Compliant System OK
IRQ 155 Microsoft ACPI-Compliant System OK
IRQ 156 Microsoft ACPI-Compliant System OK
IRQ 157 Microsoft ACPI-Compliant System OK
IRQ 158 Microsoft ACPI-Compliant System OK
IRQ 159 Microsoft ACPI-Compliant System OK
IRQ 160 Microsoft ACPI-Compliant System OK
IRQ 161 Microsoft ACPI-Compliant System OK
IRQ 162 Microsoft ACPI-Compliant System OK
IRQ 163 Microsoft ACPI-Compliant System OK
IRQ 164 Microsoft ACPI-Compliant System OK
IRQ 165 Microsoft ACPI-Compliant System OK
IRQ 166 Microsoft ACPI-Compliant System OK
IRQ 167 Microsoft ACPI-Compliant System OK
IRQ 168 Microsoft ACPI-Compliant System OK
IRQ 169 Microsoft ACPI-Compliant System OK
IRQ 170 Microsoft ACPI-Compliant System OK
IRQ 171 Microsoft ACPI-Compliant System OK
IRQ 172 Microsoft ACPI-Compliant System OK
IRQ 173 Microsoft ACPI-Compliant System OK
IRQ 174 Microsoft ACPI-Compliant System OK
IRQ 175 Microsoft ACPI-Compliant System OK
IRQ 176 Microsoft ACPI-Compliant System OK
IRQ 177 Microsoft ACPI-Compliant System OK
IRQ 178 Microsoft ACPI-Compliant System OK
IRQ 179 Microsoft ACPI-Compliant System OK
IRQ 180 Microsoft ACPI-Compliant System OK
IRQ 181 Microsoft ACPI-Compliant System OK
IRQ 182 Microsoft ACPI-Compliant System OK
IRQ 183 Microsoft ACPI-Compliant System OK
IRQ 184 Microsoft ACPI-Compliant System OK
IRQ 185 Microsoft ACPI-Compliant System OK
IRQ 186 Microsoft ACPI-Compliant System OK
IRQ 187 Microsoft ACPI-Compliant System OK
IRQ 188 Microsoft ACPI-Compliant System OK
IRQ 189 Microsoft ACPI-Compliant System OK
IRQ 190 Microsoft ACPI-Compliant System OK
IRQ 4294967290 Radeon X1950 Pro OK
IRQ 4294967291 nForce4 PCI-Express Root Port OK
IRQ 4294967292 nForce4 PCI-Express Root Port OK
IRQ 4294967293 nForce4 PCI-Express Root Port OK
IRQ 4294967294 nForce4 PCI-Express Root Port OK
What the hell is up with this????
IRQ 10 OK
geposted Thu 05 Apr 07 @ 7:54 am
I have No clue what that list of IRQ's means - I don;t know that much about software - Sky might.
If the Comp that you use to DJ with is a non-internet laptop then do the following:
Disable defender (in control panel)
Turn off Auto-update (in security center)
Turn off windows firewall
basically - surf around control panel and turn off anything related to internet security.
Also while in control panel - go to system - advanced tab - performance setting button, and set to - Adjust to best performance.
Your desktop will revert back to a Classic windows "skin"
That should get rid of a lot of processes.
Make sure that the system does not go online after doing that because you've just removed all the extra security that makes Vista really secure
geposted Thu 05 Apr 07 @ 8:04 am
I M on the system now as we speak. I WILL tell you however that the video out the 2nd monitor is cyrstal clear and not jumpy. I swear I got 42 processes running and I could still possibly do more than XP and actually make it through a night of djing. I think I might take Fri off and work on this system. The worst that could happen is that I can go back to XP (which was workin awesome) and have it up next week. I need to upgrade the ole MOBO and CPU to dual core. What freaks me out is the fact that Cyder has about the same system as me ann his is flawless. Makes me wonder how mucj BS is in this Vista cause I doo see MCE and that pisses me off.
geposted Thu 05 Apr 07 @ 8:22 am
I think You'll be able to get it working - Maybe PM cyder for some tips since he has the same hardware.
I do agree with them tht Vista is a superior OS - Good as ConQuest keeps telling us mac's are? - Dunno - but good for a microsoft product.
geposted Thu 05 Apr 07 @ 4:18 pm
I've been spending time converting and ripping Music Videos
Hopefully I'll solve some Hardware issues (video crossfader soon and might post up some mixtapes with photo slideshows/ music videos and some interesting cross-genre mixing.
I guess a Purple Onion Ulti-mix, some RnB/Reggea, some Heavy Metal, some Alt - Dance.
More of a youtube advertisment again than a mixtape for any other purpose.
They seem to be having an effect - I'm getting more people coming to the back of the DJ booth saying they've checked it out.
geposted Sun 22 Apr 07 @ 6:39 am
Brian,
where our 2 systems differ is the mk2. I don't use usb sound on my gig machine except when I'm running tests for the VV interface or djio their beta vista drivers do cause a bit of system instabilty when running but thats the nature of beta drivers. I'm using a 192l from esi out to an external mixer. I'm also using asio drivers for it in 2 output mode. I have a lot of junk from vista turned off. I was running latency at 512 but I upped to 1024 to lower cpu even more on track load. Its amazing it sits a 2% mixing two vob's Thats about it for tweeks. I have a pre-production dmc-2 also on usb. My gig machine has 9 internal drives and 2 smaller external back ups for a total of 11 drives on the system 939 single core, its smooth as ice.
geposted Sun 22 Apr 07 @ 7:01 am
The other difference between our systems is the fact that I am usin an ATI video card. Now I havent messed with the Vista since I last typed here, but I do now have it installed dual boot with XP on 2 seperate drives. Now another thing that may be screwin me up is the fact that my OSs are on IDE drives as I couldnt get XP installed on my SATA drives. If I could figure this out it may help. My machine also has 2 GB RAM. I am debating on building a Dual Core machine as I am saving my money to update. Also I have tried my onboard soundcard and still couldn't get rid of the crackles and pops and crappy sound unless I used Safe Mode.
geposted Sun 22 Apr 07 @ 7:10 am
Same here I feel the time is right to jump on the AM2 train. One good rule of thumb when trying to install an os is to make sure all your drives except the drive you want to install windows on and of course a cd rom are the only things connected. When I do an os install I make the system as basic as possible I even use a ps2 keyboard and mouse.
I had trouble with ide0 wanting to be the c drive when using vista, and of course after I worked it all out I still have a boot backup file on it, which I can live with. I also have a dual system however I just make sure the drive with the os on it I want to use is in the hot swap bay. I haven't touched xp since I switched to vista about 3 months ago.
I never had luck with the nforce audio but I really had no reason to use it with the djio and 192l backing each other up. I got some weird skipping at first just like you did, I killed the sidebar and most of it went away. After I turned off more visual junk (like the same thing for xp) and killing some un-needed processes, I finally got a stable system. It will run lower latency if i ask it to, but for the drop in cpu I'll stick to 1024. As I said before I'm not using wdm drivers, and in asio mode the safe mode checkbox really doesn't do anything.
Weird thing is that your setup as twice the ram and on paper a better video card. I dunno if ati is having issues with their vista stuff, but I know my 6600gt has none.
geposted Sun 22 Apr 07 @ 7:41 am
Makes me wanna grab an NVIDIA graphics card to try it out. Which is ok as I have another system I need to build for my dad. I may just try that. Do you have an OS on a SATA drive??
geposted Sun 22 Apr 07 @ 7:46 am
I always felt my lucky number was 3 so yes my OS is on sata #3 by itself
geposted Sun 22 Apr 07 @ 3:34 pm
Thats what I will do this week. I will do a dual boot partition on the #3 Sata drive which will be ok cause I can remove my IDE drive that has XP and if this doesnt work I can go back to that drive. I will let you know. I was gonna do it today but my Sea-Doo was more important. I took her out on the maden voyage of the year yess it was a bit cold 65 in the air and 45 in the water, but it ran as smooth as a cats ass. Brian
geposted Mon 23 Apr 07 @ 5:18 am
Well here goes:
Points of interest on this video:
- Done in Vista
- All video Effects done in VDJ - no external editors.
- Only Controller used was DAC 2 and 3 channel rack mixer.
- Props once again to cstoll for making the mapper.
- Both sound and Video cards are Motherboard intergated, nothing added
- as many as 5 video effects running simultainiously;
- Slideshow
- video rotation
- video cube
- showlogo
- sonique visualizations (might be hard to see, I had the transparency turned waaaay down)
The original mix had two more songs mixed into it. Proper Education - Eric Prydz & Wherever I Roam - Metallica. But it got rejected by YouTube because of length. Also I had to compress it down to a very small file to fit within YouTubes guidelines.
I hate rules.
Feedback about mixing and transitions will be apreciated.
geposted Mon 23 Apr 07 @ 7:44 am
