Forum: Old versions
Topic: Laptop & Video mixing
mzackPRO InfinityMember since 2006
Looking to get started mixing videos, I have a Dell XPSM140, not the greatest vidoe card for a laptop, sometimes I see a yellow or green stripe down the middle....is it the laptop?
I have a nice 37" HDLCD TV coming to add to my setup, but I think I might need a new desktop computer with a good vidoe card........does this sound right??
Looking for some assistance with vidoe mixing....thanks!!
geposted Tue 03 Apr 07 @ 4:06 am
djcelPRO InfinityModeratorMember since 2004
It can be either your video card or the way the video file was encoded.
geposted Tue 03 Apr 07 @ 4:48 pm
yk23PRO InfinityMember since 2006
This is the way I got it to work on my m140 w/ HW acceleration.
Install Video driver a07:http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R112732&SystemID=XPS_M140&servicetag=&os=WW1&osl=en&deviceid=3526&devlib=0&typecnt=0&vercnt=4&catid=-1&impid=-1&formatcnt=1&libid=6&fileid=147598
The newest and older drivers will still have the "green lines"
I can play mpgs and mpeg2 fine, vob's dont work too well- because of the driver.
Hang on, need to mix a video...... ok Im back.
I rip my videos in avi/xvid format. If you want to play avi files, remove DIVX, install the Xvid codec. Leave the AVI codec set to "Video decoder"
geposted Sat 07 Apr 07 @ 7:00 am
I follow you all the way up to here......then Im lost!
I have tried every ripping format, still have the yellow line
geposted Sat 07 Apr 07 @ 3:28 pm
Also make sure the videos are ripped with the Xvid or mpg codec. Double check the video driver in device manager shows version v.6.14.10.4410.
geposted Sat 07 Apr 07 @ 5:20 pm
I see Video driver in device manager, but no version 6.14.10.4410, actually there is no numbers at all next to this.
It just says Video Codecs with a little speaker next to it
Do I need to dowload the one you suggested?
geposted Sat 07 Apr 07 @ 6:01 pm
Yes download and install. You need to look under display adapters > intel for the version. I think you are in sound, videoand game controllers.
geposted Sat 07 Apr 07 @ 9:14 pm
Thanks for the help........But where do I find the latest driver, is there a web site I need to go to for the update
geposted Sun 08 Apr 07 @ 12:26 am
How do you delete DIVX and what do you mean? Delete what from where?
geposted Mon 09 Apr 07 @ 3:40 pm
