i'm using VDJ 4.3r12
on a duo core 2 of 1.6 gig Fujitsu laptop with 2 gig of ram.
win XP
Hi i've been asigning keyboard shortcut for effects .
but when a push fast and changing fast effects ( flanger, flippindouble,) on both decks at the same times, the program shut it'self superfast!
There are no problem doing do same thing on my VDJ 3.4
Anyones have idea?
win XP
Anyones have idea?
geposted Wed 04 Apr 07 @ 5:09 pm
Which function do you use on your keyboard shortcut : "effect_activate()" or "effect_select()"? Which value? Affected on which deck ?
geposted Wed 04 Apr 07 @ 7:20 pm
hi again!
I use the keyboard shortcut as fallow
"effect_activate(beatgrid)" on deck one,, with keyboard ( INSERT )
"effect_activate(flippindouble)" on deck one,, with keyboard ( home )
"effect_activate(flanger)" on deck one,, with keyboard ( pageup )
"effect_activate(beatgrid)" on deck two,, with keyboard ( delete )
"effect_activate(flippindouble)" on deck two,, with keyboard ( end )
"effect_activate(flanger)" on deck two,, with keyboard ( page down )
The VDJ shutdown when i press de same effect "on and off" fast on both deck rapidly
Hope this will help you understand my problem.
If someone could try it on there PC tu see if it's a probleme only for me!
Thx all of you for your support!
Dj Wish
Inbeatradio.com
geposted Thu 05 Apr 07 @ 3:20 pm
tHX FOR THE SUPPORT!
the message was given to Math
Welcome to Inbeatradio.com. Say hello to Mathieu Crevier from me please ;-)
geposted Thu 12 Apr 07 @ 4:39 am
Hi DJCEL again you said about my problem this,,, Ok it's a bug. It will be corrected.
Is tit corrected by now?
cuz i drank too much last nite, and forogt,,,,, so ,,,,,, it happend!, half-full club, VDJ SHUTTING DOWN!!!
anf the DJ was lokking like an,,,,,,,
THX Dj Wish
geposted Sun 01 Jul 07 @ 9:20 pm
If you can't handle you booze son, I'd suggest you DJ without drinking..same goes for driving..it takes extraordinary skills to both at the same time...hehe
some got it, some don't :P
geposted Mon 02 Jul 07 @ 1:53 am
