Forum: Old versions
Topic: Sync button locks up
my sync button locks up on me and the only way i can reset it is by restarting the program... not good
geposted Fri 06 Apr 07 @ 2:08 am
all of a sudden my sync button started doing the same thing 2 dats ago. I didn"t turn it on or anything and it just comes on and messes everything up and won't turn off
does right clicking it help?
and in options try setting disengage beatlock to manual
you sure you dont have it set as a shortcut? that would happen to me sometimes and i would have to close and reboot until i noticed i had a shortcut on the shift key. Look under your shortcut listed to see if you have sync listed to a key.
my settings are correct. How do i check the shortcut that you speak about. It happened to me again tonight...
Do you guys using any midi controller? maybe at there u did not off it? well, the VDJ would presume u getting the sync on or perhaps it also to do wit the shortcuts on ur keyboard :)
I had the same thing occur...I'm presuming somehow it's a sequence of keys.....always when typing....I've deleted the keyboard short cut...Why would the button lock though.....
I FIGURED IT OUT !!!!!
Keyboard short cut.... Active deck...press "B" Beatlock...it'll match the other deck and lock.....pressing B again will disengage and allow you to reset pitch.....
I can see using a keyboard, this can happen, especially when search; you simply haven't clicked on the search field and hitting B...presto....
Delete the sort cut, or change it to 2 or 3 key short cut so it's not as east to do......
