Forum: Old versions
Topic: using Gif's in showlogo
i have custome logs for the companys i work for and would like to put then in thwe lower corner of the screen but i can't load a gif in showlogo. why doesn't showlogo support a gif and slideshow does. The objective is to show the logo without seing any white beyond it. is there a fix or some kind of patch. Thank for your great support, Mike
geposted Sat 07 Apr 07 @ 5:04 am
The two plugins don't use the same code and for the moment it's not planned to add .gif in show logo.
If you save your logo to a jpg or bmp file with either a white of black background, you can then load that into the show logo plugin and use the "mask" slider to set the background colour to transparent.
What I personally do is save the files in PNG without backround and dont use a mask , because the edges are not perfect.
And its crip perfect.
So option mask simulates a transparent background but the plugin can directly use alpha layer. Try a .tga file for example.
