Forum: Old versions
Topic: Analyzing Files
Question: When I right-click (or control click) on a Folder that is set to favorites (it's red), I try to go to the Analyze files, but it's not there. When I control click on a regular folder, you get that option....
NOW -- I want it to scan all my files from the I-Tunes Library. There is a folder called "Music" on VDJ with all my ITunes files. You cannot control click that Analyzing files. At the very bottom, there is another regular folder that says ITunes Music, HOWEVER, my itunes music is seperated in each folder ... If I have it scan the main I tunes folder, will it update (show) the BPM in the Music (favorites) ?
geposted Sun 08 Apr 07 @ 3:25 pm
cstollPRO InfinityMember since 2004
Red folders are Virtual Folders and you are saying that you are not able to run the analyze from the Virtual folders?
To answer the analyze question - YES if you analyze it in any folder the results (BPM, Time, etc.) will be visible in the other folders.
geposted Sun 08 Apr 07 @ 3:28 pm
djcelPRO InfinityModeratorMember since 2004
So it's not a favorite folder but a virtual folder. It's not the same thing.
geposted Sun 08 Apr 07 @ 3:29 pm
So when you set a folder to favorites, and you have it scan the main folder, everything will show up when I click the favorites folder?
IE-- Scan the main Itunes folder, everything will show when I click the music folder in which VDJ created for my Itunes songs? (im assuming VDJ automaticly set it to favorites)
And once it is scanned, it will automaticly save that info correct? I saw in the General Forum, users were having a problem of it not saving that info ... (but that was with Home Edition -- Mk2 edition, not pro)
I have a G4 and it takes 30-45 seconds (some over a 1 minute) to scan one song. and almost 10,000 songs, lol that's aa lot of minutes. lol
P.S. Cel-- (Im sure you are) you guys are aware of that search field issue right?
geposted Sun 08 Apr 07 @ 3:57 pm
