Forum: Old versions
Topic: .wav files only plays 1 sec
k_onePRO InfinityMember since 2006
When I load .wav files in CUE, the file only loades/plays one second of it, and only 1 second of waveform is showing as well...anybody else experiencing this?
geposted Mon 09 Apr 07 @ 1:52 am
djzeroPRO InfinityMember since 2003
what sample rate are they at? you may need to resample them to 44.1khz or 48.0khz
geposted Mon 09 Apr 07 @ 1:33 pm
regular PCM 16-bit 44.1khz wav files...so that's not it...i've tried with several different files to..always the same...
geposted Tue 10 Apr 07 @ 4:38 am
Anyone else having this problem?Or is it just me?
geposted Tue 10 Apr 07 @ 11:07 pm
djcelPRO InfinityModeratorMember since 2004
Verify the option "max load". What do you have?
Which length is your file?
geposted Tue 10 Apr 07 @ 11:09 pm
I am also having this problem - it doesn't seem to matter how I have max load set, though I usually keep it at "always"... My file lengths are all less than 5 minutes.
geposted Wed 11 Apr 07 @ 2:27 am
it was set at 15mn originally, but I've now tried all settings with no luck.
I've tried both short and long files...only 1 sec loads no matter what...that it's always exactly 1 sec as well.
geposted Wed 11 Apr 07 @ 10:08 pm
