Forum: Old versions
Topic: Problem with Pc update
When I execute update_virtualdj_v4.3.exe, I got this answer:
Could Not Initialize Installation: Flie size expected: 2502258, Size returned 2501804.
Anyone could help me?
I've already dowloaded the file twice.
Many thanx.
geposted Fri 13 Apr 07 @ 7:01 pm
what download program are you using?
I've tried with firefox and explorer...
Same issue here,
any help is appreciated
Try deleting the file from your drive and redownloading it from the download centre. It's almost as if you didn't get the full file when you downloaded it in the first place.
Good luck...(",)
P
Same problem!!! I'm using brand-new computer with Windows Vista Home Premium, Internet Explorer 7
I'm trying to install Virtual DJ 4.3 (full install)
PROBLEM SOLVED!
Date: Thu 19 Apr 07 @ 17:23:59
Teamer: Coyote
Message:
Hi,
The message you receive (in your first post) mean an incomplete (or corrupted) download.
It can be a Vista download bug, can you try to download by using the "right click" on the link and "save as..."
Best Regards
Date: Thu 19 Apr 07 @ 17:42:08
Customer: DJRogerBorges
Message:
Yes, it worked!!!! THANK YOU!!! I will post the answer at the forum for the others to know. VDJ rocks!!
aslo do not use a download manager to download the files as they are protected.
