I downloaded the Pioneer skin interface... it looks great and functions extremely well with added triggers. Does anyone else have any good skin references?
geposted Sat 14 Apr 07 @ 10:08 am
V Mix 4 video is the only one I use, The V Mix 5 have a lot of info, but it's too much for me.
I like the "CUE" version/VDJ4 is the best.
geposted Sat 14 Apr 07 @ 11:58 am
I used to use the defaul audio skin. But since the Mix Lab skin came out, that's my weapon of choice. Very professional looking and has all the functions right there.
geposted Fri 20 Apr 07 @ 6:16 pm
Thank you!!!
DJ FORMAT
geposted Fri 20 Apr 07 @ 10:50 pm
@ shenanigansmusic
Try to download my skin v2.1 (1024x768) ready for VDJ 3.4 (Hercules MP3 & MK2 DJ console user) : http://www.virtualdj.com/addons/skin.html?id=2322
geposted Sat 21 Apr 07 @ 11:27 am
DJ FORMAT wrote :
Thank you!!!
DJ FORMAT
Thank you!!!
DJ FORMAT
No, Thank you!!!!! :)
geposted Sat 21 Apr 07 @ 7:17 pm
I actually like the tascam skin. mainly because of the loop buttons and the layout. The cue skin is cool, but when i use cue my hercules headphone select does not work.
geposted Fri 27 Apr 07 @ 10:06 am
Hercules headphone cue midi command is "headohone_crossfader", you can see this crossfader movement on the top of my skin.
CUE on deck 1 show cursor top left or CUE on deck 2 cursor top right.
Download skin link http://www.virtualdj.com/addons/skin.html?id=3196
![](http://img147.imageshack.us/img147/140/image17un3.jpg)
geposted Fri 27 Apr 07 @ 10:38 am
