Forum: Old versions
Topic: options under "Edit Automix" are not saved
Under the window "Adjust BPM values" is a tap called "Edit Automix"
It's possible to change these settings, but when I click on OK, and close this window, these new settings are not saved.
What am I doing wrong, or is this a bug.
Can you help me please?
I'm using the latest version 2.02 on a laptop with Windows XP Home edition SP1 not installed, and on another PC with XP professional SP2 installed.
(Both have the same problem)
geposted Wed 15 Sep 04 @ 12:01 am
Can anyone help me, because nobody replied on this question
In fact it seems as though there may be a bug. I was unable to successfully set these points. Thanks for your find I will report it to Dev Staff.
