Forum: Old versions
Topic: ICDX problems
Below are a few of the problems I would like to be addressed in future releases/updates.
1)
I'm having an issue with using the platter to rewind and fastforward through a track. If I'm playing a track on deck A and I'm cueing up my next song on deck B and I'm moving the platter in a fast movement forward or backward it will affect the song playing on the output by slowing the sound down and adding a static sound.
2)
I'm sure this has been noted already but the video output is randomly activated when using the platter?
3)
Also randomly if I'm playing a track and I just touch the platter it will go back to the beginning? This happened to me once... I'll repost if it happens again.
4)
I know this isn't a bug but the backspin it shite :|
If anyone else has had the same probs feel free to confirm.
geposted Thu 19 Apr 07 @ 3:24 am
The point 2 is already on the TODO list of the dev staff.
Point 3 with TCCD ?
Other points are interesting. Try to give us more details on the way to improve,....
point 3, are you double clicking on the platter? think I've seen this before. it has to do with how the skins coded.
point 1, sounds like you are right on the verge of your soundcards lowest latency, try boosting it up one notch and see if the static disappears.
Ok I sorted out problem 1. Just had to play with my soundcard settings to get where I wanted.
I havent come across the track jumping when I touch the platter in a while now. I'll be sure to post again. I possibly may have double clicked it?? cant remember.
I just had my first crash yesterday in more than year and a half yesterday. I had selected a track using the wheel knob on the icdx and I changed my mind while it was still loading and loaded another track. Everything froze up but the music kept playing. The blue rotating windows vista ring was just showing more or less telling me to wait. Even the time display on the ICDX unit stopped althought the track kept playing. I had to close & restart.
I'm using vista btw.
