Forum: Old versions
Topic: MK2 Bypass
Anyone else experiece horrible sound quality when using the bypass mode on the MK2 to play regular CDs? Is there a way to improve the settings so it sounds clear or are the Y-splitters the only good way to bypass TCCDs and play regular cds?
geposted Thu 19 Apr 07 @ 8:00 pm
sorry i havent had that problem myself yet
It has to do with the input volume. I am sure someone else will chime in here. Your best bet is to not use regular cd players through the MK2 and use an external mixer. Correct me if I am wrong.
which cd players do you use?
Well, Cd players have high output, but you can lower Input volume of MK2, I think.
Im using CDJ 1000s hooked up to a DJM 800. i used to get fuzzy sound when used with my toshiba laptop with xp. now i have a hp laptop with vista and i get absolutely no sound when in bypass mode. drivers are all updated and im using the lastest version of vdj.
i have the same problem with playing regular cd's...sounds horrible,especially id the song has alot of bass... whats the solution???
im usuing a gemini cdj-01 and its directly plugged into the mk2
