GaryBr wrote :
I'm finding that sometimes the plug in cancels out a video i'm playing, and if i manage to get the video playing again, the text dissappears and vice verca. Sometimes it works fine, other times the text stops the video playing and i kist get a black screen with the text.
Gary
Gary
It appears when you close the video window. I''m still investigating to find the reason why but for the moment i don't find.
geposted Thu 17 May 07 @ 4:59 pm
Am i the only person its happening too DJCEL?
Gary
Gary
geposted Thu 17 May 07 @ 5:08 pm
It happens to me too. What's YOUR specs ??
geposted Tue 22 May 07 @ 2:20 pm
DJcel, is this being worked on at this time?
Just wondering?
Bryant
Just wondering?
Bryant
geposted Wed 23 May 07 @ 4:38 pm
My Laptop is HP DV9288ea
Full spec here :
http://h10010.www1.hp.com/wwpc/uk/en/ho/WF06b/21675-38187-38191-38191-38191-12936524-78126925.html
Gary
Full spec here :
Gary
geposted Wed 23 May 07 @ 4:43 pm
Gary wrote :
"I'm finding that sometimes the plug in cancels out a video i'm playing, and if i manage to get the video playing again, the text dissappears and vice verca. Sometimes it works fine, other times the text stops the video playing and i kist get a black screen with the text. "
Gary
DJCel wrote:
"It appears when you close the video window. I''m still investigating to find the reason why but for the moment i don't find."
New question: DJCel, is this or has this issue been fixed or resolved yet? Just curious as to when it may be. Thank you for a fine plugin.
Gary
geposted Wed 30 May 07 @ 5:48 pm
DjCel, where are ya on this one?
geposted Fri 01 Jun 07 @ 4:05 pm
dj cel is very busy at the moment
he will be back when he can be :)
geposted Fri 01 Jun 07 @ 5:50 pm
Thank you Sky, I'll be patient now.
geposted Fri 01 Jun 07 @ 6:20 pm
On the text 2D, it shows up in the lower right corner but seems to require a skin of over 1280 x 1200 to show the whole text 2d screen. Is this just me or should it work "wholly" on any size VDJ screen , such as a 1080 x 724??
geposted Fri 13 Jul 07 @ 8:46 am
I have just uploaded a new version of Text2D.
Please report if you have issues as I had to rewrite a big part of the code to make it Unicode compatible.
geposted Sun 01 May 11 @ 7:02 pm
Same problem as above.
The text2d gui in the lower right corner, cannot see all the options. Using 1366x768 skin
geposted Tue 03 May 11 @ 7:17 am
New version 2.1: compatible Keyboard / MIDI
You can now use "video_fx_button 1" to switch on/off the text n°1
You can now use "video_fx_button 10" to switch on/off the text n°10
geposted Fri 06 May 11 @ 4:10 pm
Thanks Cel ! got it....
geposted Sat 07 May 11 @ 8:11 pm
I have just fixed the Focus issue (when you loose keyboard control) after using the plugin. version 2.2 uploaded
Now you shouldn't have any issue with "video_fx_select "text2d" & video_fx_button 1"
@Developers: I have used the following code:
if(bEdit == false) SetFocus(hWndParent);
geposted Sat 14 May 11 @ 6:27 am
Why the hell didn't I think of that?!
geposted Sat 14 May 11 @ 6:42 am
Can't find Text2D plugin in the site..?
geposted Sat 14 May 11 @ 11:04 am
It's now available again. I have found a little bug in the code so I have just uploaded a fix.
[EDIT] If you want to play with font, try "Wingdings", and type the letter "J" in the edit Text area
geposted Sat 14 May 11 @ 12:06 pm
Looking forward to trying this.:)
geposted Sat 14 May 11 @ 12:16 pm
Thanks, Cel
geposted Sat 14 May 11 @ 12:23 pm
