Forum: Old versions
Topic: Vestax VCI-100 Mapping for VDJ
Just uploaded the Vestax VCI-100 mapping onto the plugins page. This is my first try. Unfortunately the jog wheels are not mapped yet, but as soon as it can be done I will upload. This is probably a temporary solution as I hope that VDJ will make the controller supported natively. I'm sure they will.
I've mapped it fairly close to the original labels on the controller, buta so far haven't done the fx sections. If I get chance over the next few days I'll do some more and upload a description of what each button does, but I guess you'll soon find out if you try it. The browser up and down and load buttons are all there, as arfe the cue and sync commands. The silver discs on the controller temporarily stop play, but won't move through the track or scratch yet. Still, it is possible to do a good house set with it as it is now. If anybody can give me some help with the jog wheels I'd be pleased to finish this off.
Please don't expect this to be absolutely perfect as I did it with my wife sitting next to me telling me a very detailed story that I can't remember now. ;-)
geposted Sat 21 Apr 07 @ 4:22 pm
Hi Asymptote,
I just bought the Vestax VCI 100, it's great. My MK2 is also great but I'm tired of hitting the jogs when I need to hit the sync buttons and I'm having so much problems with Traktor and latency issues.
I'd like to use the VCI with VDJ. Do you know if VDJ will support this natively soon? Were you able to finish the VCI mappings with VDJ? I've downloaded the one you've currently upload but not sure how to import it into VDJ. I have ver. 3.4.1 Home Edition and the Midi device section in the Remote Control is grayed out, do I need to purchase the Pro version?
Thanks in advance.
Hello,
thanks for your work!
I added some new features like Sample play and effects control! The Jog wheels actually i used as bitch bend. My main Problem is not to scratch with the weels but i want to search in the song but i cant fix it!
Thanks for your Help, but the problem in your settings is that if i turn the wheel than the track goes forward and then backward.
melsen2007-
Thanks for the info. I've downloaded the Pro Trial and was able to import the XML.
Hopefully the VCI will be fully supported. And to all who are deligently trying to get this to work,
many thanks.
DJRomz
