Forum: Old versions
Topic: I need Help - Please Help Me Rip Vinyl
Sup guys,
i have a problem with recording with Rip Vinyl Prog evrytime i try to record with it it doesn't record at all please can anyone explain to me how to record with that program?
thanx
geposted Sun 22 Apr 07 @ 6:55 pm
do you get a message?
yes i do i get a message of saying - Impossible to find lame encoder DLL.
anyone help?
download and extract this
www.free-codecs.com/download/Lame_Encoder.htm
into the program folder
c:/programfiles/virtualdj/
should now work.
i downloaded all of those files and extracted all of em but i still get the message and the same problem i had before? what should i do now please help .
thanx
anyone help?
ok sounds like a reinstall is nessary
step 1.
back up your databases
virtualdjdatbase.xml
virtualdjdatabase(yourname).xml
mp3database.txt
these are located in the folder.
step 2
use the registry cleaning tool from this website to clear the registry
step 3 reinstall and place files back
ensure the codec is there
then try.
all u have to do is go into config and change ur sound card from Primary to ur actual sound car ... well tat worked for me ..no need to reinstall or download anything .....jus try that ..go into config and select ur sound car or whatever card ur using to record the track
lame codec not found , is related to not being able to find the mp3 encoder dll
Just select the decoder in the config of Ripvinyl (button next to the bitrate). It's useless to uninstall the software.
i don't get u guys ? what do u mean by the Config And Bitrate? explain it for me plz ?
ok he means press config.
and look for an option to locate the .dll
point the program at the encoder and choose say 192 kbs.
okay nice it works but now i get this error which it can't save the file :))=)) What the hell :))
this is the error: impossible to save'c://balahalaahahaha.......mp3.'
can anyone help me on that thanx i have to record something 2day please help fast :D :X
try lowering the encoding rate.
finaly worked but :)) =)) pc recorder is better than this one damn :(.
Thankx you all :)
