Forum: Old versions
Topic: TIME CODED VINYLS.....???
DooYa1PRO InfinityMember since 2005
I don't have an ASIO soundcard yet, but it says I can still use the TCV’s with the 2 soundcards I have, VDJ 4.3, AMD Athlon 64 3700+ 2.20GHz Realtek AC'97 & Creative Soundblaster and am using GEMINI TT02 Turntables and I rotate using the GEMINI 02 & PS-04 mixers. I quite don't understand how to configure the ASIO driver to use TCV with the equipment I have. Is there something I need to do to the 2 soundcards? Can you please bless me with some of your knowledge to figure it out?
geposted Sun 22 Apr 07 @ 11:29 pm
listen2PRO InfinityMember since 2005
are you using ASIO4ALL?
geposted Mon 23 Apr 07 @ 2:18 pm
yes
geposted Mon 23 Apr 07 @ 3:13 pm
do both cards appear active in asio4all?
geposted Mon 23 Apr 07 @ 5:23 pm
Yes.
geposted Tue 24 Apr 07 @ 6:43 am
ok well now your going to have to describe what is the problem exactly. What options are selected in the sound config? Do you see waves in the timecode config. windows? Are you sure your cables are connect correctly?
have you looked at this? http://www.virtualdj.com/products/timecode/
geposted Tue 24 Apr 07 @ 2:12 pm
