Forum: Old versions
Topic: bpm problems.
I been playin around with this demo and when i manually enter a bpm... virtualdj rewrites the bpm when its loaded into the deck. Is there a way to disable virtualdj from automatically analysing the track again?
geposted Mon 23 Apr 07 @ 2:38 pm
I am pretty sure that you need to analyse the track first. Then you can edit the BPM and it should keep changes.
Yes that is
ilost my bpm's how can get them back i have a full back up of my music can i copy a file from one pc to the other and the bpm will show or is there a softwear that i can get that will wright them fast i need them for aparty tmmrow
If you have a copy of your databases in some place other than the system. You can delete the databases on your system and then copy the backup one and paste them. All should be okay
And if you don't have a backup of database, try Database repair tool here.
