Forum: Old versions
Topic: U46dj .............. HELP PLEASE
I jus baught the U46dj ASIO but weh i try to connect it i get error in the asio sound driver
can any one help me
geposted Mon 23 Apr 07 @ 10:12 pm
Even if it is connected, you will still get an error message until you have gone into the VDJ config menu and assigned the U46dj as the sound card you want to use with asio.
Sometimes when restarting VDJ, the settings will default to the internal soundcard, or will do this if the U46dj isn't plugged in.
Try assigning all the settings correctly for the asio driver and the soundcard, exit VDJ and start VDJ again and if everything is connected and configured correctly, you won't get the error message.
Gary
you need to use the 1.016 driver, that seems to work best for most u46 users. Once that is installed plug in the u46 and power it on, wait about 5-10 seconds and then open vdj. The card has to be active before opening vdj or it wont see it. Also if you open vdj without the u46 plugged in and active then vdj will give you a "not enough channels" you will then have to close vdj and then plug in the u46 gain make sure is on and is active, then reopen vdj.
In rare cases when you do not follow this method you will have to check in the ASIO config box where you can select the u46 latency setting, sometimes the output/input(not sure which actually) box will be unchecked. Just make sure its checked off.
i got it to wrok but it seems like my usb port cannot power the device
i eventually had to buy and external power unit ... is here anyone in hee whic the u46dj is directly powered from the usbport
Mine is... what happens when you try it?
it says power surge on port .. the unit cannot be powered by this port the every thing else get knock out of the usb ports ... and nuttin work is prolly jus my pc .because it old
