Does anyone know how to map the jogwheels on the vci 100... I can get everything else to work but the jogs, i can get them to stop, but i can't get them to go forward or backwards.....
THIS IS AN AWESOME CONTROLLER :)
geposted Tue 24 Apr 07 @ 1:26 am
CAN YOU SPEAK SPANISH
I TRY TO HELP BYE
I GOT ALLREADY HOW IT WORKS
BYE
I TRY TO HELP BYE
BYE
geposted Tue 24 Apr 07 @ 4:47 am
I TRY TO HELP BYE
BYE
I TRY TO HELP BYE
BYE
how did you get it to work? Please use bable fish to translate your answer.
¿cómo usted lo consiguió para trabajar? Utilice por favor los pescados bable para traducir su respuesta.
http://babelfish.altavista.com/
geposted Tue 24 Apr 07 @ 11:51 am
No trabaja .. yo necesito ayuda para hacerlo funcionar.. El controlador trabaja pero las ruedas no.
geposted Tue 24 Apr 07 @ 11:03 pm
Did you try this to map the jogs ?
1) Select the function scratchwheel() in the list
2) Select the mode "relative"
3) Set a scale of 32 768
(so it will be 32 768 / 4096 = 8 )
[for 4 (scratch more sensitive), set a scale of 16384 ]
[for 16 (scratch less sensitive), set a scale of 65 536]
[for x, set a scale of x*4096]
geposted Thu 24 May 07 @ 7:28 pm
