Forum: Old versions
Topic: Video Problem: Yellow Line in Video
When I am playing video in Virtual DJ, I have a yellow line that runs down the middle of the screen and is visible in the preview, window, and output. It comes and goes, but it there on all videos.
My computer is brand new with 2gb of ram, so that isn't the issue, but I cannot figure out what the problem is.
You can see what it looks like at http://www.dabears2k.com/vdjvideo.jpg
Thanks for the help in advance.
geposted Sun 29 Apr 07 @ 11:33 pm
Well before answering you, where did you get this skin? It's a very powerfull skin for professional editon users only.
The line is usually caused by not having a good enough video card. Yes, even on a brand new laptop with 2gb ram. Please post your complete specs AND the answer to DJ Cels question
Rusty
buuusted
I'm having the same problem..... What video card(s) do you guys recommend. I'm looking into purchasing another laptop for just video and dj use. or do you have a specific laptop model that I can look into purchasing. I am a fan of Toshiba, not so much dell! so anyone out there that is using a toshiba and running good with VOB files please let me know what model toshiba you have.
Thanks all!
Keith
Get some model that has 7600Go or GT and you should be fine.
