Forum: Old versions
Topic: Help wit MK2 and VDJ
i jus bought this package and im very satisfied with it. i jus got a few question
1. i bought the one wit the headphone input, i would b listening to both decks at once so i can get the right part into my mix, now wen i mix i like to throw the crossfader in the middle, then throw it back, but if i throw the crossfader a little over half way i cant here both songs on my headphones, like i have deck A playing, then i got a loop of some words on deck B, i throw the crossfader in the middle, and throw it back, but all i can here is deck B on my headphones. is there anyway to fix this?
2. if im playing a track in deck a, and load one in deck b, it automaticcaly does a beat match for some reason, can i fix this so it doesnt do a beatmatch?
3. can someone explain to me the video fx thing? i saw it and it saids like strobe effect and stuff
4. is there anyway to make a loop longer? i no they give u three but i wanted to loop a part of a song but i dont get all of it, is there any way to make the loop longer?
thanks in advanced
geposted Mon 30 Apr 07 @ 6:15 am
thanks in advanced
Being able to hear both songs in the headphones: on the MK2, you have cue adjustment button - place it in the 11:00 or 12:00 position... the other positions is for listening to one deck at a time. ( like on a standard mixer and the cue button )
At some point you may have hit the auto beat match button either on the MK2 or on the software. depress the MK2 ( if thier is a red light in middle on either side- it's active )
Video FX is not mapped to MK2 controller, however; depending on your video card if the FX can be active on your computer system.
The MK2 is mapped to 1, 4, 8 beat loops... if you want longer loops, then use mouse to click desired loops or learn the keyboard shortcuts.
thanks a lot ill try that out later.
i figured out that the auto beat thing was on enabled automatically so i fixed that, ill try the loop thing in a moment
