Forum: Old versions
Topic: Think I fixed video problems, BUT....?
Well., I'll be dammed, I think I might have got videos running smoothly on my lappy dell duo-core
after 9 months of screaming at 4.2r1.
Here's what I did:
A) Defragged 500 GB ext. HD even though it was 2% fragged..
B) Set second monitor to 16 bit, 800 by 600, while leaving lappy screen at 1024 x 728 using 1024 x 728 skin.
Videos and transitions, along with sonique visuals(most of them) on slideshow for audio's, and a showlogo in the background all seemed to function without any pauses or freeze-ups for 4 hours continuous.
BUT....The one thing I couldn't get to work was the "text" for video captions found in the old 3.4 default skin that I use for 4.2r1. What would cause the "text" function NOT to work? In the video square between the two volume level indicators, there is a little text button that opens a little box to type in text that shows up as a caption on the video or visual playing at the time. Remember, I was using 4.2r1 for this four hour period. Is there a different way to apply these captions (other than the new Text 2D plugin)?
geposted Tue 01 May 07 @ 3:33 pm
The Text module is in VirtualDj v4.x a plugin now called Text
I referred to the NEW plugin called Text 2d in my post and am aware of that, but where do I find that original one you are speaking of?
It directly comes by default when you install VirtualDJ
Thanx, found it. Now what will the text 2d addon plug in, include in addition to this?
Better and more features :)
Really nice actually!
Is it working properly in it's prsent "beta" form. I have read of a few complaints.
Am I wrong and should I, at this time, go ahead and install w/o fear of any repercussions?
