Forum: Old versions
Topic: VDJ 4.3 in Japanese Vista x64
Currently I use VDJ on a Japanese XP Professional x64 installed computer and have done so for the past 6 months. Well if the world must know VDJ doesn't read Japanese at the moment but that isn't my worry so much as stability. Until now I've just experienced the same problems as most of you e.g. white noise, long file loading problems and frozen videos etc. So a 64 bit computer isn't that much different when it comes to problems. There have been a few comments about improved video in Vista and I was wondering in there is anybody out there using VDJ in a 64 bit Vista environment who can say it rocks or it goes hsssssss after 30 minutes. Yes a lot of problems have been solved but I'm shit scared to go to Vista even though I'm ready.
geposted Wed 02 May 07 @ 3:07 pm
Which sound config do you use with which sound cards?
Describe at the same time your computer
